throwing code help
chb504
my check engine light has been on for awhile. on my last civic the cel came on and it turned out to be the o2 sensor, so i changed that on my civic now, the light is still on... so i looked at this thread https://hondaswap.com/forums/index.php?showtopic=29806 and i tried to do it but i couldn't figure it out. I found a 2 pin out plug that was plugged into a green rubber harness, the wires were green and brown, so i thought this was it, but the "light show" didn't happen... i found a brown plug that has a black wire and a blue/white wire. i was wandering if this plug is the one i need to "jump"
thanks
danny
i changed the o2 sensor a while back on my hatch and i did reset the ecu after, and the light is still on... the guy i bought it from took out the a/c compressor and raidiarto and the 2 hoses that go from the radiator to the passenger side of the car... can this be throwing the cel
