Throwing Codes?
Discussion in 'General Tech and Maintenance' started by shuturmowth, May 6, 2003.
Thread Status:
Not open for further replies.
  1. shuturmowth
    shuturmowth Senior Member
    cali
    what do you mean by throwing codes? how can i check this???
    oh and how do i find my vtec wire???(d16y8, 96 EX)
  2. cheesyweesy
    cheesyweesy Junior Member
    throwin codes means u got a problem, hook it up to a scanner see what happens. and your vtec wire is kinda under your distributor, look at a wiring diagram wid for your civic
  3. shuturmowth
    cali
    ummm....... scanner?????
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    You don't need a damn scanner. The will be a plug under the passenger side dash. Use a paper clip or equivalent to jumper the plug. Read hown many times your CEL flashes. Long flashes are the ten's column, short are the one's. It may have several codes in there.
  5. 96 turbo teg
    96 turbo teg Junior Member
  6. junhondasi
    junhondasi Member
    plymouth MN
    WHEN PEOPLE START TALKING ABOUT PAPER CLIPS SOME GET SCURED HES RIGHT U CAN BUT JUST A SHORT PIECE OF WIRE CAN WORK JUST AS GOOD JUST PUT IT IN ONE SIDE OF THE PLUG AND INTO THE OTHER MAKE A LOOP IT SHOULD BE A 2 WIRE PLUG BUT ON THAT CAR I'M NOT SURE WERE IT IS LOCATED MABY SOMEONE ELSE CAN TELL U WERE OR GO BUY A CHILTON HANES OR HONDA SHOP MANUAL ON YOUR RIDE THEY HAVE LOTS OF GOOD INFO IN THEM AND HAVE ALL OF THE CODES LISTED FOR LATER WHEN YOUR SHITS WACK AGAIN.
  7. lsvtec
    Kill the caps lock.
  8. junhondasi
    junhondasi Member
    plymouth MN
    LSVTEC I GOT THE CAPS ON TO PISS SOMEONE ELSE OFF AND THE DEAD KENNEDYS STILL RULE
  9. lsvtec
    Doing something specifically to piss someone off is really dumb and really childish.
    In their current incarnation the Dead Kennedys suck ass. In the days of Jello Biafra they ruled.
    :locked2:
Thread Status:
