Tial 50mm Bov
Discussion in 'Forced Induction' started by CiViC>ALL, Jan 19, 2008.
  1. CiViC>ALL
    CiViC>ALL New Member
    hello im new to forced induction to can anybody tell me how a tial 50mm adjustable bov works? can i controller my boost pressure going into the intake with it? thanks
  2. Briansol
    a bov has NOTHING to do with boost pressure. It relives the stress on the turbo from backflow when you let off the gas (TB closes, boosted air has no where to go... saves the turbo from winding up backwards).
    a wastegate controls your boost pressure.
  3. CiViC>ALL
    yeah i understood that but why would you want different spring rates then?
  4. Matts96HB
    Matts96HB . Moderator VIP
    The wastegate spring is basically the lowest amount of PSI u can run. Say you have a 6lb spring. You cant run any lower than that, but you can stretch the spring to run more. They do have a limit tho.
  5. CiViC>ALL
    im not talking about the wastegate, the bov
  6. Briansol
    its just a setting on how fast/strong it releases. it needs to see x before it opens to release. thats all
  7. CiViC>ALL
