ticking vtec
you could have a bent valve or need to adjust the valve lash
ive had the same problem on my 97 integra with b16. I would only hear it when engine is at normal operating temperature. I didn't know what was causing it but once i replace my intake manifold and put in new o ring on my injectors it work fine. good luck
bigboto: thats exactly what mine is doing!! im running just a stock gsr manifold. maybe if i go aftermarket it would could away... ill have to try it if it doesnt go away with a vavle adjustment
LMAs...
Old style LMAs tend to stick. And all our motors are old now. Honda's new design is a single spring which will never stick.
I'd bet money on it.
