Quoted post[/post]]
You were proven wrong yet you still try to talk shit? I dont get it. I still dont know where you are getting these magical prices, I gave you links to actual prices. The civic coilover and shocks are going cost more if you went with konis but you should already know that right? probably not, they require a special ring to fit on the koni sleeve. So if he did have a civic he would be looking at around $1000 for konis not to mention if he included top hats and custom rates like most people do when they go that route. Konis arent for someone thats looking for a daily driver like myself or hosmer so why even bring it up, they werent in his list or were you d spec crap whatever.
Seriously, shut your friggin mouth.
"Your d spec crap whatever". You sure are a suspension guru, right? You know all about Tokico D specs and their 16-way dampening, plus the fact that they have a build quality thats as good as the konis for a lot less. Unfortunately, they don't have the struts for his application...yet.
Konis are more for a daily driver than any retarded coilover combination you can come up with. There is better dampening which will help soak up the bumps on an everyday road. So actually, you're off your rocker - and the konis are going to be one of the best possible daily driver setup you're going to ever find. Coilovers are usually adjusted too low, so they don't get the optimal performance that they're supposed to, causing less suspension travel and hell for a daily driver not to mention really rough spring rates.
Look at high end cars, are they riding on really good struts or coilovers - they're on struts, because coilovers wouldn't be as practical for a daily driver.
My prices are from a google search and an ebay search. If you're that much of a retard and you can't pull prices yourself - screw you, I don't need to do all the leg work for you.
I never mentioned upgraded tophats, camber bolts, camber plates, custom spring rates, or anything else fancy like that - so don't put words in my mouth.
Basically, you went with tanabes for a daily driver?? If thats the case, you're out of your league.
