I have been having trouble starting my b16 since I put the motor in my car. I thought it was the distributor and replaced all the parts within the distributor, still no spark??? Anyway I decided that it must be timing and thought that my timing belt was tight. I installed a new one when the motor was out of the car. I noticed that it seemed a little loose. Then I cranked it over a little and this was what happened: http://www.angelfire.com/dc2/calvinbrandel/civic/0062.JPG
After that cranked it all the way around just to make sure that it was not broken and it looks fine. As I was cranking it though, it seemed to be slipping and the right cam would turn faster creating the gap in the timing belt again. Anybody have any ideas? Do I need to just tighten it back up, by taking it all apart again?
Also I was wondering if anyone know what this peice is on the starter, it has a hole in it for a bolt. I also noticed that it had a charge running through it when I hooked up a multimeter to it: http://www.angelfire.com/dc2/calvinbrandel/civic/0060.JPG
