Timing Belt Brands differ in quality?
preludude
Member
Is it worth spending the extra money into buying original honda timing belts? The non-OEM belts are far cheaper than the OEM belts, but will they last just as long?
It is a rather important part of the engine, and I'm not sure if its better to just pay a little more for peace of mind.
Do you guys use 3rd party timing belts or OEM only belts?
i used a ebay generic timing belt and it was the worst thing ever
2 weeks after the installation i had to change it out cause the belt was wearing away and there was the belt dust everywhere
get an oem one, trust me
Originally posted by pissedoffsol@May 22 2004, 12:06 AM
OEM or a bling TODA belt would be the only thing i'd consider
yeah, an OEM timing belt just feels that much more better when you grab it...feel a gatorback timing belt from autozone, then feel an OEM belt.
I agree, to me the piece of mind whort the extra cost for a OEM timing belt
Good luck
:concur: would only use oem or toda, and since i don't have the $$$ for the toda, I only use oem honda
Yea, thats what I figured, the OEM is probably the better way to go. Anyone know where I can get the best price on them? :)
Do I need to get tensioners too?
I know I need the water pump and balance belt while I'm down there.
u should replace them, they wear out and dont tension the belt to the right tension after a while. replace water pump while ur at it...
<- Using a GReddy timing belt. Very good quality belt, haven't had any problems and no sign of wear.
Get a new tensioner. I didn't know to do this when I replaced my timing belt. 30k later, my tensioner bearings exlode, little bearing balls everywhere inside the timing belt cover, and I still don't have my car running 8 months later. I am poor. :(
