Timing Belt Change
Discussion in 'General Tech and Maintenance' started by Killt, Apr 9, 2003.
  1. Killt
    Killt Junior Member
    Need to know how to remove the bolt that holds on the Crank Drivebelt Pulley (Harmonic Balancer). AN 1/2 impact wont break it loose. I tried a large breaker bar jammed up on the engine mount , put the car in gear and draged it and the tires just skid any ideas? Its a Civic
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    You can get a crank pulley tool from Honda, Snap-On, or some companies online if you can wait. Otherwise, take it to Honda, have them crank it, then tighten it again, drive home and remove it yourself.
  3. legutki
    legutki Senior Member
    find an impact wrench
  4. Honda Special Tool #9356-03 made by Snap-On. Or Honda Master Tech Tool Series SF15-T135 part number SF15-0014. This is a special wrench use to open it.
  5. dohcvtec_accord
    The left lane
    Those look like the ones. Makes life infinitely easier. An impact gun won't always do it, unless you've got a hella-nice gun and compressor.
  6. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    when i had to get my harmonic balancer off my civicthis is what i did...i took off the plate that covers the flywheel from underneath the car (duh) and stuck a screwdriver in it so it wouldn't move...so i held it there and had my girlfriend break the bolt loose...that's how i got mine off
  7. dohcvtec_accord
    The left lane
    That's how I did it when I had my H22A out of my car, pre-swap. The crank pulley tool doesn't do you any good then. :D
  8. brian11to1
    brian11to1 Senior Member
    you turn it counterclock wise.
  9. Havok
    Havok Senior Member
    Florida
    WTF? I think we have established which way tightens and which way loosens.
    Air tools are your best friend, I got some Craftsman for 279.99 it came with a 3/8 ratchet/impact wrench.
