Timing belt question
Discussion in 'General Tech and Maintenance' started by allmotord16rex, Sep 20, 2004.
  1. allmotord16rex
    allmotord16rex Senior Member
    Anderson, SC
    I have a DOHC ZC and I was just inspecting my timing belt because I am thinkin about goin turbo. Well, I looked at it and on the left side the belt is being worn down pretty badly. It is about 1/8th of an inch wide and it goes around the complete built. Has anyone ever seen this before. Is it from my timing belt cover or is something down in the timing cover are rubbing it. I am goin to put a new timing belt on and I need to identify the problem.
  2. 94RedSiGal
    94RedSiGal Senior Member
    Massachusetts
    How old or how many miles on that old timing belt?
  3. 94RedSiGal
    Massachusetts
    Well it's either a very old belt that is about at the end of it's life... or if it's a relatively young belt, the belt was either defective or installed wrong...
    The first replacement timing belt on my Si was poorly installed or defective. Literally it was done one day, and the next I was on a 1100 mile road trip to Atlanta. I was getting poor gas mileage (ran out of gas once where I shouldn't have) and there was a slight knocking during acceleration. I called the mechanic from the road and he suggested it was due to buying cheap gas. So I get home with 2300 miles on my new belt... and insisted that the dealership check my new timing belt. They didn't want to, but I prevailed. And so it turned out that my belt was nearly shredded... they almost owed me an engine rebuild. As it was, several hours later, I left with a replaced timing belt for free. I didn't push to find out if it was a bad install or just a defective belt. As long as my car was happy and I didn't have to pay for it, that was good enough with me. So that is my experience with a bad timing belt. Otherwise, I never forget to change them on schedule or earlier.
  4. B16
    B16 Super Moderator VIP
    yay area, CA
    :yes:
    this happened to me, check it out ASAP
  5. allmotord16rex
    Anderson, SC
    Well, what was the problem with it? How did you correct it? Was something rubbing on it down inside the timing cover? By the way, the belt probably has around 70k miles on it and it is being damaged on the top of the built. This leads me to believe it is my cam cover, especially since the debris from the belt is in the cam gears. Any suggestions?
  6. B16
    yay area, CA
    lol, i quoted exactly what it was i found... your answer was there.
    inside the timing cover, a small bolt had fallen out and was rubbing between the timing cover and the belt down at the crank pulley. i would highly suggest checking this out before starting the car again.
  7. allmotord16rex
    Anderson, SC
    Could the tensioner pulley be causing this. It makes a whirring noise when the engine is running? I will check to see if something is down in there though.
  8. 97CTR
    97CTR Senior Member
    Just change the belt, when you have all of the covers off, check for bolts etc. Change the tensioner pulley while you are at it, they are pretty cheap.
    After that you should be okay, just check it out often at first to make sure you didn't miss something.
  9. 94RedSiGal
    Massachusetts
    Well at 70K it was getting close to the time when your timing belt was due to be replaced... how many YEARS since it was last done though. These belts age. Since this belt is not original to the engine, perhaps the person who did the last install didn't replace the tensioner pulley with a new one. Good thing that you pulled the cover to look at it...
  10. b204dr
    b204dr Senior Member
    Minnesota
    genrally it will happen when some thing gets inside the timing chain like bolts or other things like people have states.. also if your tensioner is not proper put on can cause uneven wearing of ur timing belt
  11. pissedoffsol
    60k is the first service for honda timing belts. 100k for the 2nd.
    i'd go for a 3rd around 140k
  12. 94RedSiGal
    Massachusetts
    Is that recommendation since he wants to go turbo or is it a DOHC thing? Otherwise, are you saying that the replacement timing belts are only good for 40K miles? I've always heard to change them every 90K (or 70K under severe driving conditions for a B-series engine) miles or six years.
  13. b204dr
    Minnesota
    dealers recommend every 90k or 6 years.. but only you as the driver would know heh if you drive norm then yea . but if u like to ride ur car then what he sais goes heh
  14. lswhitecivic
    lswhitecivic Senior Member
    DFW, TX
    I think that 90k miles is only for new cars. Late model cars need new ones every 60k miles. Also the harder you are on the car the less mileage you should go before a new belt.
    Ben
