INJEN78
HS LEGEND
i cant get my timing to stay right,
set te cams to te correct spot,set the crank pulley to TDC,using the one tick mark all by itself,lining it to te mark on the belt cover,now when i crank the motor over it jumps a tooth,what could be the problem??
am i missing a step or something?
also trowing a code 8(TDC sensor),and the motor will not start
