hey whats up, i got a 97 sol vtec wit a b16. im changing the timing belt, water pump and drive belts. i was wondering if i should change the timing tensioner too, if so how whould i go about doing this.
If it's not noisy or loose you don't necessarily need to change it, but it is a good idea. To change it you just remove the bolt holding it to the block and bolt the new one on.. it's basically just a pulley that has a bracket attached to the tensioner spring..
