Just wondering if a turbo application is similar to nitrous. Do you have to compensate by retarding your timing and if so how many degrees per psi?? Thanks, Mike
Originally posted by b16rex@Aug 25 2004, 04:19 PM Just wondering if a turbo application is similar to nitrous. Do you have to compensate by retarding your timing and if so how many degrees per psi?? Thanks, Mike
The conservative "retard per psi" for turbo setups is about .8-.95 degrees per psi, never to fall below 7 degrees. These are only used to set base maps to be built apon with further tuning. Over-retard and advance back to perfect.
cool thanks guys!! Also I was just wondering about my wastegate. I have a 35mm tial with a 6 pound spring. When the wastegate senses full boost it lets out the extra right?? Or does it let all the boost out to where you dont get anymore? When I get in to the upper rpms I hear a woosh sound(wastegate opening?) then I feel like I hit a wall losing power?? I initially thought of fuel, but my a/f gauge is still in the green. Dont know whats going on!! Please help... Thanks Mike
Originally posted by b16rex@Aug 26 2004, 12:20 AM cool thanks guys!! Also I was just wondering about my wastegate. I have a 35mm tial with a 6 pound spring. When the wastegate senses full boost it lets out the extra right?? Or does it let all the boost out to where you dont get anymore? When I get in to the upper rpms I hear a woosh sound(wastegate opening?) then I feel like I hit a wall losing power?? I initially thought of fuel, but my a/f gauge is still in the green. Dont know whats going on!! Please help... Thanks Mike
Maybe your blowoff valve is set too loose allowing it to open and bleed off boost at the wrong time? You really should have a general understanding of this stuff before getting it on your car..... :unsure:
Actually this is my second turboed car. I had a 99 si with a drag gen 3 kit and I had no problems whatsoever. Thanks for your help though!! I'll try the bov!!
