hondanamics
Member
my timing is off need someone to fix asap. 91 honda accord will pay. laurel jessup savage area in maryland. email me at hondanamics@msn.com or leave me an email address
Originally posted by GSRCRXsi@Oct 20 2004, 12:33 AM
you should be able to get the timing close enough by hand for the car to start. just put the distributor close to centered on there. that should be close enough. if it doesnt start still then you have other problems. timing belt could have jumped a tooth or something. check out all the marks on your crank and cam pulleys. set the engine to TDC on cylinder #1 and if all the marks dont line up then the timing belt is off and will need to either be replaced or adjusted. if everything is cool with the timing belt check to make sure you are getting proper spark and fuel. also this may sound dumb but make sure that the plug wires are on in the correct order.
[post=405059]Quoted post[/post]
