timing my mini me swap?
Discussion in 'Engine Building' started by HondaElite, Mar 12, 2008.
  1. HondaElite
    HondaElite senior member
    fall river.mass
    i have a d16z6 head on a d15b6 block i changed the oil sensor already..but for the timing am i supposed to use anything from the z6? like timing belt water pump..or even under driven pulley? thanks for the help
  2. HondaElite
    fall river.mass
    ok well i found out that i need the z6 timing belt and water pump..and an adjustable cam gear..i heard that im jus supposed to set the cam gear for a half a tooth off and time it..and its all set
