timing problem
Discussion in 'Civic and CRX - EF' started by efalex, Nov 21, 2008.
  1. efalex
    efalex New Member
    Danville NH
    i think... when i give it gas, it takes like half a second to go but before it does it bogs down...
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    damn,thanx for letting us know
  3. austin20110
    austin20110 New Member
    Northern Va
    lmao
    sounds like turbo lag
  4. mikey bottles
    mikey bottles Prof. Bottles
    S. Jersey
  5. Fernpatch
    Fernpatch Member
    Bellingham,WA
    If your fuel system has any kind of high miles on it I would get the fuel rail and injectors cleaned. Having dirty injectors restricts fuel flow and more importantly can cause the spray pattern to be off and not atomize the fuel correctly. If the problem is worse when its cold and gets better and higher rpms/engine temp than I would be thinking of a fuel issue for sure. From what I have seen your best bet for cleaning your injectors is removing them and having them ultrasonically cleaned or to have a motor-vac service performed by a shop. Good luck and let us know how it goes.
    1 person likes this.
  6. efalex
    efalex New Member
    Danville NH
    yeah turbo lagg maann :)
    no but htnaks fernpatch Rep +
