tinsel strength
cointelpro
what is tinsel (spelling) strength? ive heard this used in refference to an engines durability and i was wondering if anyone here knew?
i know i can find it online somewhere but i figured if i asked here maybe some other people who wanted to know would be able to learn as well, so dont even flame.
i believe its spelled
TENSEL strength
and i believe it is the strength of steel....at which point it will break?
someone correct me if im halfway there, or completely off....
hehe yea i figured it had something to do with that, but how do they measure it? i mean do they make wires out of the metal and then break them or put the whole engine in a HUGE ass vice and sqeeze it to death (ITS A JOKE DONT FLAME) or what?
haha no flamming here, I woulda said it was how strong that silver stuff you hang on your christmas tree is...
Yup yup you are correct. It means how strong a metal is untill it's breaking point. As for measuring it, there is a formula for each type of metal. It goes by the type of metal, thickness, force upon the metal, also I think(I think) The type of force placed upon the metal! Like pressed together, sheering force, twisted force and so on. Every thing acts differently in different types of forces! I hope you understand what I mean here. I have no idea of the formula's or how to compute them! try to do some searches for it!
i believe it is set in a machine, and they kinda sorta try to bend it. they look for stress cracks in the metal...and give it some sort of a rating.
its "tensil" and it has to do with the strength of pretty much any material (wood, paper, water, etc...) not just metal
the best answer i could give would be go to google and search around for information on it
It is "Tensile" strength, and it is a measure of tension. Imagine holding a rope (or whatever) in both hands and try to pull it apart. The rope is under tension when pulled upon, and it's tensile strength is the amount of force that will cause it to break.
<-- materials science and engineering major with emphasis on mettalurgy...
tensile strength is correct.
on a stress strain curve of a material there is a point called the UTS... ultimate tensile strength. the specimen doesn't fail at this point, it is just the point where necking begins to occur.
it fails soon after that, but once it hits the UTS if you release the load on the object it will not return to its original shape whatsoever, thus it has undergone plastic deformation.
before the UTS, there is a certain percent of it that will return (elastic deformation) to its original shape...
quick ghetto diagram example
what happens after necking ?
Originally posted by ek9r+Nov 28 2003, 02:27 PM-->
pills_PMD
The material will be permently deformed.
The material has been loaded beyound it's elastic limit
and as pills said it's a ratio
Young's Modulous of Elasticity ; E= Stress/Strain
and ideally you want to operate or never produce more load on the material no more than 25% of the value of (Offset Yeild Strenght) often just called yield point. in that situation the material should last indefinetly.
you were askin how they test the strenght, most of the time it's a destructive test.
an instron test device is used and they pull on the wire and note the force it took to break the wire.
To calculate these forces that will break a material you could do an FEA (finite element analysis) or you could do a simple experiment and measure the forces before breaking etc...
Descent reading material.
This is the core business that my company works with everyday.
My Works Website
it'll show you a bunch of various products availiable to measure Force or Pressure
neato. great information! so, before you begin to neck, if the stress is relieved the metal will return to some of its original shape, IE, a once perfect line becomes 1-5 degrees off, but if you keep going it may break or become fucked the hell up, IE perfect line becomes 45 degrees off. correct? and do you know how they would do this test to engine blocks?
Engine blocks are not rated or tested in this way to the best of my knowledge. The only grading I have ever come across is on bolts. Pills- can they test this on an object wihtout uniform shape?
typically on an instron machine, a specimen looks like the following:
it will typically fracture in the center where the cross sectional area is weakest.
then depending on how that shape specimen performed, you can transform its properties to materials of odd shapes and non-uniform cross sectional areas, though the place of greatest stress is at areas where the cross sectional area goes from large to small, like in an I beam where it goes from the horizontal section to the vertical section of the I.
so.. they dont use this test on engines? some guy told me "b16a2s are the best b16 gen becuase they have the highest tensile strength"
he sounds like an asshole to me. they are cast aluminum blocks. unless they are alloyed with a higher percentage of carbon or some other hardening material then i am wrong.
