tinting carbon fiber
Discussion in 'Body / Exterior / Interior / Cosmetics' started by h22a hatch, Dec 1, 2011.
  1. h22a hatch
    h22a hatch New Member
    was wondering if anybody on here ever tinted any carbon fiber before. I was a car show, droptoberfest, and a guy said he has a shop that does it and they jus get, for example, a carbon fiber hood and dip it in blue tint and then the carbon fiber has a blue tint to it but u can still see the weave of the carbon fiber. Was wondering if anybody on here did anything like this. If you would just use a sheet of window tint and it would have the same effect? Im wanting to do that with my carbon fiber hood expect red tint not blue. Any help would be appreciated.
  2. SlushboxTeggy
    NJ to MA to CA
    I've seen it done with paint. Just something transparent/candy. THe black shows through, and the gray/white picks up whatever color you choose. I guess it could work with tint. Kind of like the vinyl wrapped cars, just transparent.
  3. JoeDaddy
    JoeDaddy New Member
    Dallas, TX
    Yeah I do this at my shop a lot, like SlushboxTeggy said using candy is the best way. The concept of using tint would work but would not be very durable, would scratch very easy. Depending on how much your looking to tint you wouldn't need very much candy, some automotive paint stores might even give some samples to play with. If it was me this is what i would do, take what ever you want tinted and sand it with 500 or 600 grit wetsand paper then take it to a paint and body shop and ask them to spray some red candy over it but ask them to mix the candy with some clear, candy is usually mixed 2 parts candy to 1 part reducer to 1 part hardener but you want them to mix the candy with clear so the mixture would be 1 part candy 1 part clear to 1 part reducer to 1 part hardener, you'll have a nice durable finish, you can even ask them to spray another coat of just clear by itself for more durability. Keep in mind with candy paints the more coats you apply the darker it gets. Sorry about the long post but just wanted to make sure you had all the info you were asking for, hope this helps. Oh and the reason i said sand whatever your wanting tinted first before taking it to a paint and body shop is because it will be way cheaper if you do the sanding, you might only get charged 75 to 100 bucks for them to just spray it.
  4. h22a hatch
    joedaddy...thank you for the long reply it was very helpful and im pretty sure i kno exacttly what to do now...thanks for the help
  5. JoeDaddy
    JoeDaddy New Member
    Dallas, TX
    no problem and your welcome.
