Tips or help before i begin my swap
Discussion in 'Civic and del Sol - EG and EK' started by turbowizard, Nov 4, 2006.
  1. turbowizard
    turbowizard New Member
    Dear members,
    my name is michel and i live in da netherlands. I own a honda crx del sol esi from da year 1994.
    I have bougt a H22a JDM 2.2liter Dohc vtec prelude engine with 220 hp with wiring harness and ecu and gear box , everthing ! complet engine block that i want to swap. And my hasport engine billets and axles are coming.
    But i have al lot of Q because this is going to be my first engine swap ! i am a car mechanic so i am good with my tools and getting da engine in wont be a problem ! butt connecting some things can maybe give a problem ! so i want to know if there is someone thats has done it , or knows about it !
    a few Q are :
    hasport motorsports also has a wiringharness , do i also need to order that ? is that a harness so i can connect my gauges en speedometer ?
    how is the gear / shift linkage ? do i need a prelude linkage or can a put the del sol linkage on da prelude gear box ?
    Is the fuel rail or fuel line da same ? can i put the fuel line of my del sol on the fuel rail of the prelude engine ?
    I have got a engine harness with my prelude engine and a ecu , butt if i ve got that and i connect my fuel line and my starter and i give the ecu his volt , shouldnt it start and drive ??? the gauge s dont wont than of course butt the engine should run right ?
    Do i have to change my powersteering line to da prelude pump or does the del sol line fit in to da prelude pump ?
    this is it for now !! Anwers are welcome and if you have any others tips of suggestions let me know ! you can also mail me @ michelbeekman@hotmail.com
    THNX , greetz michel beekman, Turbowizard Developments
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    your gona need a 1990-93 accord fuel rail 90-93 accord half shaft and your gona need a accord or prelude shift linkage.and your power steering is not gona fit unless you do some major modding
  3. turbowizard
    Thnx !! my tech englisch is not super , what do you mean accord half shaft ?
    Do you know a way so i can use my powersteering ? usa other pump or something ?
    any other tips or does someone have different idea or seggestions ? All is welcome ,
    And thnx for you anwers !
    grreetz
  4. AHHVTEC
    Alabama
    halfshaft/ also-intermedet shaft it goes on the back of the h22a
  5. formby
    formby learning in progress
    please read the post before you send him on a hunt for axles
    he's getting the alxes from hasport
    i belive you reuse the cable linkage from the swap, and the shifter from an 96-01 accord... not 100% sure
    and the harness is ok to get because of the ease of reinstallation but its $$$. i couldnt tell you much exept that you already have the right axles...
  6. AHHVTEC
    Alabama
    my bad tru tru
  7. random_hero
    random_hero New Member
    thats a pretty difficult swap for a first time swap!
  8. turbowizard
    You are right butt thank god i know some off the best tuners in da netherlands !! a friend of mine i see on shows has a b18c in a del sol en a other guy i know has had every engine in his del sol incl a h23a and later a s2000 engine ( randall from Hontec ) ! If i cant do it i can knock on this door , but i am now trying to get as much info before i see them on the next show.
