Tire Pressure Gauge
Discussion in 'Wheels / Suspension / Tires / Brakes' started by |Chaz|, Sep 21, 2008.
  1. |Chaz|
    |Chaz| Well-Known Member VIP
    Anyone want to recommend a quality tire pressure gauge? Right now I'm just using one of those that has the thing that pops out the end. It has increments of 1 psi up to 50 psi. I've heard these types aren't very accurate though.
  2. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    What do you trust more, mechanical workings, or computers?
    They have digital gauges... but I'm skeptical the sensor will wear out or will show incorrect readings.
    I continue to use one of those your talking about and let physics tell me. If you really really wanted to be sure, go nab like 2 or 3 different brands of those and check the psi with each.
  3. George777
    George777 ^^ Likes Bewbies
    With your mom
  4. |Chaz|
    That's not bad, do you know what it's accurate to? +- 0.5 psi/+- 1 psi?
  5. George777
    With your mom
    I don't know. I do know that when I used to used it, it was never off any of the other gauges that were in the shop.
    Mine currently sits in a box in the garage. I don't use it any more.
  6. E_SolSi
    i just use the cheesy Accu-Gauge dial ones with the bleeder vavle from Autozone or wherever. they read accurately enough for me... im not so concerned that the pressure they read is accurate within .0001% of actual PSI in the tire as i am of the gauge reading consistantly. i keep one in each of my cars and only use that gauge to check and adjust my pressures for that car. as long as i know that on that specific gauge 40psi front and 37psi rear or whatever (varies by car and tire) gives me correct pressure for a full contact patch with no roll over on hard corners im good
    1 person likes this.
  7. newb
    newb phresh VIP
    Backwoods Northwest
    I use a Monkey Grip gauge that I got at Schucks, and I like it. Its got a dial gauge and a bleeder. I like reading the dial gauge better, but thats just my personal prefference. I keep using it for the same reason E uses his, its super consistant. If I get an erratic reading Im sure that its the tire and not my gauge.
  8. efhondakid
    Akron-Canton, Ohio
    Ive always used the pop out kind and have never not trusted the accuracy of it, I am a little weary of the digital gauges though.
  9. dacheat
    dacheat ..is grounded.
    strongbadia
    i use and hate the cheapo 'turkey's done' style gauge; maybe because i'm a little bit OCD and i end up checking each tire 5 times and throw out the two lowest readings, and average the other three :D
    i've been wondering what the hell kind of gauge would do any better, so i'm glad you asked, chaz!
    :thumbsup:
  10. |Chaz|
    I was reading about just how big of a difference tire pressures can make in the performance of your tires if they're off by a few psi so I figured here would be a good place to ask.
    I'm planning on ordering this one here pretty soon, thanks for recommending it George777.
    TPGF60, Tire Pressure Gauge, with Hose, Dial-Type, 5 to 60 psi
  11. phyregod
    phyregod !!YTINASNI
    Central Texas
    About the best style you can get. Mine is the same, but without the hose. Holds pressure until you hit the release valve. No re-sealing for another reading, easy bleeding. Good stuff.
  12. |Chaz|
    Yay just ordered the snap-on tire gauge. George777 was going to sell me his, but it ended up being broken for some reason. Good luck with getting yours replaced George.
  13. George777
    With your mom
    Thanks man. I guess now I will get the experience of seeing what the replacement/exchange procedures are with Snap-On.
  14. |Chaz|
    Keep us updated on how easy/hard it is.
  15. phyregod
    phyregod !!YTINASNI
    Central Texas
    Step 1: Call truck
    Step 2: Say "this shit is busted!"
    Step 3: .......
    Step 4: Profit!
    Really, snap on usually replaces tools on the spot, free, no questions asked.
  16. George777
    With your mom
    I just gotta find out when one will be in the area.
    Do I have to provide a receipt or something? Or as long as it's Snap-On, it's covered?
    Not meaning to threadjack...Sorry man.
  17. |Chaz|
    It's no problem. I'm curious just how their warranty works also.
  18. dacheat
    strongbadia
    ok well looks like i'll pick up one of those this fall then - thanks everyone for the opinions, and to chaz for askin!
  19. |Chaz|
    Definitely recommend it. It has a nice weight, and it works well. How's trying to get yours replaced going George777?
  20. George777
    With your mom
    Honestly, I haven't even attempted yet. I started working the graveyard shift last week, and haven't had a chance to find out who/where to contact. Once I find out, I will let you know.
    Good to see that you like it. It's a little more expensive than most average people would spend, but in the long run, it will pay off...
