eyesonlybob
i have kuhmo ecsta (however you spell it) and it says the max psi is 44. do i fill them to 44, or is there a margin i should use? thanks
Originally posted by CRX-YEM@Jun 16 2003, 09:59 PM
you typically don't inflate a tire based on what the tire says. look on the inside of the door jam it will give you tire pressure specs for the front and rear tires. I usually keep mine ast about 32PSI
