Tire size: 00' si wheels, CRX
Discussion in 'Civic and CRX - EF' started by DivineSpeedRaceTeam, May 21, 2009.
  1. DivineSpeedRaceTeam
    DivineSpeedRaceTeam New Member
    Flint, MI
    I was trying to figure out a good tire size for my 00' Civic Si wheels, they will be going on my CRX. my crx has about an inch and a half drop or more.
    Anyone have some suggestions and maybe some example pictures?
    Thank you.
  2. Briansol
  3. 95b16coupe
    95b16coupe New Member
    ct
    that about sums it up.
  4. DivineSpeedRaceTeam
    Flint, MI
  5. eg6sir
    for a crx i'd go with a 195/50...
  6. phyregod
    phyregod !!YTINASNI
    Central Texas
    :werd:
    Factory specification is a 185/60/14 for a stock Si.
    Bump that to 15's and the closest match will be a 195/50/15.
    They are .3% smaller, which will lead to microscopically better acceleration and a hair less weight. The 205/50/15 will be 1.5% bigger, which isn't a big deal. But you'll be heavier and slower (again, minimally) but you'll have a slightly wider contact patch, which will lead to slightly better cornering but worse gas mileage due to the extra drag.
  7. GlassHeadlights
    Calgary, AB
    I like the look of 195 better than 205, the profile looks smaller. Especially with Falken Ziex-512, they look sexy in a 195/50/15. Imo.
  8. phunky.buddha
    Dallas / Fort Worth, TX
    You'll have straighter sidewalls on the 15x6 Si wheel with the 195/50. The tires are dirt cheap too, especially if you buy the top of the line tires on the market.
  9. DivineSpeedRaceTeam
    Flint, MI
    so 195/50 would be a better bet it seems. a lower profile is what im looking for.
    Thank you all.
