Tire size help question
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Eros2180, Sep 7, 2007.
  1. Eros2180
    Eros2180 New Member
    Hagerstown, MD
    Ok, I have a 93 Sol i bought from a guy and he has 17 " on it . The tires he has on are 205 40 17 they are shot, i found a set of 4 same size for 250. should i keep this size or should i get a different size?
  2. E_SolSi
    if you are staying with the 17s get those
    you should look in to a 15x7 inch wheel with some 205/50s on it
  3. Eros2180
    Eros2180 New Member
    Hagerstown, MD
    well im gonna get rid of the 17s and buy stock si wheels whenever i get some extra money. I really hate buying a new set of tires just to run on for a few months but i dont really have much of a choice right now. Ill keep the Si wheels and get a new set maybe next spring
  4. pissedoffsol
    a set of tires is gonna run you 400-500 bucks, easy.
    you can pick up si's with tires for the same price. look around
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    Hit ebay, you can get a set of decent rims with used tires on 'em for $500ish. That'll give you more time to save up for a good set of tires.
    GSR fat 5's have always been a favorite of mine, as are the Si rims..
    p.s. You'll be amazed at how much more peppy that del sol will feel with proper sized rims / tires on it.
  6. team1320_k24eg
    team1320_k24eg down shifting to 5th
    San Diego
    :ditto:x2
