to camber or not to camber? and what shocks :)
Discussion in 'Wheels / Suspension / Tires / Brakes' started by civiclxb16, Feb 27, 2007.
  1. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    Ok i am working on my susension. trying to get all my parts together i am about halfway there with what i wanted to do. the car is already lowered when i bought the car. so here is the list of what i wanted to do or get.
    rear disc conversion (check)
    front camber kit (check)
    new shocks because mine are on h and r springs with stock shocks (aka BUMPY and it hurts like hell!)
    front sway bar
    rear sway bar (check kinda)
    tie bars
    shock tower bars
    ok so that is what i want to get done. what i was wondering is about the rear camber. my lowering springs are h and r so its about 1.3 or 1.5 in the rear but my wheels look pretty staight. i changed out my steelies for some ls mesh rims and i had no tire wear on the inside of the rear tires but i had in the front. so i was wondering should i even bother getting rear camber kit or just leave it as is? also what kind of shocks would you guys get for daily driving? not to pricy maybe 300 bucks for all 4. let me know what you guys think!
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    Look up the washer trick. It'll safely correct very minor rear camber issues.
    If its really -1.5 thats pushing the edge, but its not over it. Hell, it'll corner better and wont eat tires that bad..
    *edit.. I would highly reccomend neuspeed sport springs and shocks. Great look, awesome ride. No bone jarring or bottoming out. Firm enough for spirited drives.
  3. civiclxb16
    Poconos pa
    when i go home i am going to check to see if it is centered i am not sure what h and r is on the rear lowering but i will check in a min. but again i have no tire wear on the inside at all!
  4. TurboMirage
    KYB AGX and H&R springs :)
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    +1 for the kyb AGX's. I had a set of those, loved em.
  6. civiclxb16
    Poconos pa
    ok i searched on summit for those shocks that will run me 400 bucks just about blowing my suspension budget. i have to be tight but strict on my susension build thats why i said i have only 300 more to spend :( i spent so far
    180 front camber
    180 rear disc conversion
    40 on the rear sway bar
    saving 200 for swaybars, tie bars, wheel alignment all that other stuff
    so that leaves me with 300 bucks for the shocks and stuff. i mean if i have to i will put more in it but my wife is looking over my sholder to see how much i spend on this setup. trust me she is mad at me about my FC and all i am doing to my civic is finishing my suspension..lol
  7. phyregod
    phyregod !!YTINASNI
    Central Texas
  8. civiclxb16
    Poconos pa
    didn't think about ebay but its a 92 civic "dx"
  9. civiclxb16
    Poconos pa
  10. phyregod
    phyregod !!YTINASNI
    Central Texas
    the KYBs have a lifetime replacement warantee.
    No idea about the SK2's...
  11. civiclxb16
    Poconos pa
    wow really? even if you get them off ebay?
  12. TurboMirage
    yes! as long as you have the paperwork with them and dont lower them more than 2 inches :)
  13. civiclxb16
    Poconos pa
    ok kool i didn't know that now i know and i will mostlikely get those shocks then got to wait on my paycheck first :)
  14. eg6sir
    i'm gonna be going with some AGXs as soon as i can afford a new spring/ shock combo.. i'll probably go with some Sportlines
