Todays project
Discussion in 'Engine Building' started by xj0hnx, Mar 20, 2004.
  1. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Picked up the man around 1045 and headed out to the shop, go settled in and car on lift around 1130. Prepped it all (removed driver side wheel and valvecover), and was ready to begin...
    Old cams out :)
    Comparison shot between the CTR cam on left, and the B16As on the right...
    A shot of the reason the Honda dealer here can't work on NSXs anymore, since he and the only other liscened guy quit. There is NO shade tree in this guys game, and one of the only people in this country I will let inside my motor...
    And I learned something today, here is a small hole, like the one on you cam that allows you to insert a 5mm brace, in this case a drill bit, into it to hold the cam while replacing your cam gear...
    Oh yea, and we threw in a new timing belt that I have had laying around meaning to go on for about a year now. And a word of advice to all those that ask about taking off the pulley, use the damn right tool, Honda makes it for a reason and it is remakably easy task with it...
    Well, Mike set the valvelash to the minimum, and I mean minimum clearance 0.15 on the intake and 0.17 exhaust, because the bigger lobes will be noisy, but we wanted to lessen the risk of floating a valve at those beautiful high rpms.
    And the butt dyno says "Power is increased all the way through and up to 8000 rpms", But next week the real dyno will tell the truth, as we all no Mr. Butt dyno can get too excited by new parts. Vtec didn't slam like I thought it was going to, but there was a marked difference in the low rpms, which is opposite of what I was expecting, anyway, once I get the real results in I am hoping to break 160 at hte wheels, as these better be good for 5+ whp. And eventually I am going to get around to some ITR springs, so I can truely take advantage of the cams, and upgrade way later on.
    Anyway thn after scorching the town I came home and vacuumed, so thanks for checking it out, if anyone has a question reguarding this, drop a dime yO!!!
  2. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    coo00l coo0l :thumbsup:
  3. E_SolSi
  4. jamesA
    Sweet action man...how much did those CTR cams set you back?
  5. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
  6. xj0hnx
    C.C.TX.
    Traded them for some EDM EG headlights, and rear seats with head rest :).
  7. jamesA
    haha
    BAH...where are you finding all these bad ass deals?
  8. xj0hnx
    C.C.TX.
    Keep my eyes open and ears to the ground ;)
    The deals are out there, you just gotta find them. Trust me, I have paid my fair share of over priced parts over the years.
  9. JDMilan
    Boca Raton, FL
  10. GSRCRXsi
    MD
    does honda sell that tool? pics of the tool?
  11. Bns773
    Bns773 Member
    Austin, Tx
    You can buy the tool at summitracing.com for $67.00
    Crankshaft Pulley Wrench, Honda/Acura
  12. xj0hnx
    C.C.TX.
    I really meant to get a shot of it in action, but we were moving pretty fast.
    It fits in the large hex shaped hole on the outside of the pulley, and you brace it against the frame and then turn teh bolt with a large breaker bar.
    Honda part #07JAB-001020A Pulley Holder Attachment, Hex 50mm
    Turns what I have seen as a day long or more ordeal, into a two second job.
  13. JDMilan
    Boca Raton, FL
  14. ef_hatch
    ef_hatch Member
    all i had to do is use my impact gun to take off my crank pully... it just turns so fast that it comes out and the engine didn't even turn over
  15. xj0hnx
    C.C.TX.
    Tha works sometimes, it the nut isn't stubborn. But if the motor is in the car, is is easier to use the tool.
  16. pissedoffsol
    did you adjust the cam gear settings at all? you'll most likely want to play with them a little to get optimal results
  17. E_SolSi
    stock cam gears y0!
  18. pissedoffsol
  19. xj0hnx
    C.C.TX.
    Hahaha, E's observasion skills own you :D
    But cam gears, and wideband own me :(
  20. phunky.buddha
    Dallas / Fort Worth, TX
    :werd:
    I picked up a good 5-6 pounds of torque just playing with the cam gears, and that was without even trimming in more fuel. We were just playing around to see where the power curve went.
