Tokico Illuminas With Skunk2 Coilovers
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Slammed90Lude, Mar 14, 2004.
What shock should I use?
  1. Tokico Illuminas
    100.0%
  2. Koni Yellows
    0 vote(s)
    0.0%
  3. Kyb AGX Adjustab
    0 vote(s)
    0.0%
  1. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    i know i should spend the money on a real coilover setup, but unfortunately i can afford a Section setup like some of the more wealthy members....*cough* B *cough*....haha- anyone running this setup and liking it? or can any recommend a better set of shocks, since the car already has the skunk2 coilovers installed
  2. TurboMirage
    kyb agx :) B)
  3. xkwzt21
    xkwzt21 Member
    i had the skunks and tokicos, but i didnt care for my skunks too much...now i have the GC's and tokicos, and its okay, but i want something that is a little more adjustable, like the tein's or the koni yellows. But all in all its not a bad set-up, i guess it sorta depends on what your planning on doing with your car.
  4. EG6_down5hift
    EG6_down5hift Junior Member
    Ground Controls are great, but teins are even better. For a low budget, get GC
  5. Slammed90Lude
    milford, PA
    i already have the skunk2 coilovers
  6. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    I have the Tokico HP shocks with my Skunk2 coilovers and they are FAR from valved correctly for the springs. The Illumina's are just adjustable versions of the HP's and still aren't valved aggressively enough for the S2 coilover springs. I hear that the Koni yellows are the only non-full-coilover system that can handle the S2 springs on the coilover kit.
  7. xkwzt21
    xkwzt21 Member
    :ditto: I would have to concur
  8. pissedoffsol
    tiens suck :thumbdown:
    never again for me. i'm probably going to sell the ha's and get a set of the sections for the del sol too.
    but on a skunk2, i'd def run a koni yellow. its stiffer, and the skunk2 springs want that.
  9. Slammed90Lude
    milford, PA
    oh thanks guys, i guess koni yellows it is- I know that they are externally adjustable, but does anyone know if they have the detent like the KYB shocks (the little clicks that let you know what setting you're on)- again, thanks guys
  10. TurboMirage
    you adjust the yellows on top of the shock piston.
    the agx's, some are 4 way adjustable on top (usually fronts) and 8 way adjustable down bottom (usually rears).
    im running H&R lowering springs which lowered me ~ 1.3 in the front and ~1.2 in the rear. in a week or so ill be able to see how well it settled. :D
  11. BlackFrog
    BlackFrog Neighborhood Lush
    North Freakin' Idaho
    AGX's can also be 4 way, adj. on top in the rear. thats how they were for the del sol. 99-00 Si's are 8 way on the side though. its vehicle specific how it will adjust.
    The AGX's definitely arent valved right for skunks, i blew my rear ones out pretty quick (though the front are still good).
    Dont forget to get the adapter thing for the yellows to work with the Skunks.
    -Chris
  12. Slammed90Lude
    milford, PA
  13. BigJ
    Not to jack your thread, I just got skunk2 coilovers on my rex. They are stiff, lets just say.
    I'm going to be going with koni Yellow's. I was told those will be the best for theset up, being able to valve the very high spring rate the skunk2 coilover has.
  14. Slammed90Lude
    milford, PA
    yeah that is what everyone has been telling me too- Since the skunk2's are already on the car i'm going to go with the koni yellows once my tax returns come back B)
