took out the power stering pump, need help
Discussion in 'Accord' started by 91accordwithwork, Jul 25, 2008.
  1. 91accordwithwork
    91accordwithwork kid that everyone loves!
    Wauwatosa WI
    hey guys my sterring pump siezed up so i got a smaller belt and bypassed it, i took the whole strertring system out, is that ok or will i come accross problems later?
  2. 91accordwithwork
    Wauwatosa WI
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    You should be fine. Just make sure there's always fluid in there though to keep the rack lubricated.
  4. 91accordwithwork
    Wauwatosa WI
    i drained the fluid out,?? if i put some in it will have no where to go unless i wana get fluid sprayed all ove my engine ?
  5. K2e2vin
    Raleigh, NC
    you need to loop the lines install a "breather" tank(essentially the reservoir). Check out the threads on Honda-Tech(PS removal).
  6. 91accordwithwork
    Wauwatosa WI
    kevein can i live without doing that? or can it mess somethign up? and idk how to loop the lines, can u explain to me how?
  7. stevennn09
    stevennn09 Member
    Ohio
    he said look on honda-tech yo.
  8. K2e2vin
    Raleigh, NC
    Definitely just search "power steering delete" or removal on H-T, there's many ways to do it.
    If the P/S lines are still hooked up to the P/S pump, it will make steering harder.
  9. 91accordwithwork
    Wauwatosa WI
    i have all the lines and tubes just hanging there, and i tore the old broken P.S pump out
    so what do i do now u guys?
    thanks
  10. K2e2vin
    Raleigh, NC
    Get a brass nipple and some clamps, cut off the ends of the hose where it hooks up to the pump; and just bypass it. That's probably the easiest way.
  11. 91accordwithwork
    Wauwatosa WI
    do i need to do that??
    what will happen if i drive as is?
    im j.w
  12. K2e2vin
    Raleigh, NC
    Fluid will leak out, steering rack will begin to wear out, "rough" steering, etc.
  13. 91accordwithwork
    Wauwatosa WI
    ok i dont want that to happen?
    but i really dont know how to bypass it or w.e?
  14. sufikation
    sufikation Active Member
    Fruitland, ID
    just research it homie.
    1 person likes this.
  15. 91accordwithwork
    Wauwatosa WI
    nah i think ill just leave it with the hoses, plugged with tolit paper
    caus ei dont no what im doing?
  16. sufikation
    Fruitland, ID
    huh? is that a question? sorry you lost me.
  17. 91accordwithwork
    Wauwatosa WI
    im syaing that since i dont no what im doing and how to bypass it, i will just leave the tubes hang i guess?
    can u help me?
  18. sufikation
    Fruitland, ID
    you can easily help yourself by doing about 30 mins worth of reading on the subject. im sure if you cant find it here you can google it. dont let it hang with tp and dangling hoses...keep it clean and what not, but most important, do it right the first time. good luck.
  19. newb
    newb phresh VIP
    Backwoods Northwest
    WTF is with all the god damn question marks?????
    You've got 2 lines in your rack. Get a breather tank, hook one port from your rack to one port in your breather, and the other port on the rack to the other port in the breather. Done.
  20. 91accordwithwork
    Wauwatosa WI
    i have to go buy a breather tank?
    so basicly get one hose to dump fluid, the other one to suck fluid in , so its in a rotaion?
