torque on headbolts? B18a1
what is the torque on the headbolts? I know it has to be done three times a different lbs. I need info.
Thanx
usually its only two steps, call an auto parts store they might tell you, auto zone can look it up on their computor and tell you I'd try them. you should find the torque sequence too. correction you should spot the 16 buck and buy a Hanyes manual
I do it in two steps, thats the way i've always seen it done....look it up the haynes manuel, you do it about half way the second half, i want to say 52...but I am DEFINITLY not sure...so look it up or wait for someone else...
