torqueing pattern?
Discussion in 'General Tech and Maintenance' started by eg6sir, Oct 28, 2005.
  1. eg6sir
    yea like the title says i need the torqueing pattern for the intake manifold for a b16..thanks for anyone who can help...
    i know you are supposed to go inside out...but not sure on the order
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    this is for d series
    can't get info on B series
    96-00 helms 68 mb
    lots of helms on the DL (downlow/download)
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    Just do it the same way as that^
    :ph34r:
  4. eg6sir
    will i need a torque wrench to do it or can i use my reg. rachets
  5. VTECin5th
    Phoenix Az
    torque wrench is RECOMMENDED.
    i put mine on with a motherfucking ratchet and then a regular wrench , then the ratchet, then got pissed, then the smoke break , then the ratchet, fuck working on preludes.
    I had no problems of leaking or anything without a tq wrench tho
  6. eg6sir
    my buddy was tellin me that dont force it...just tighten it with one good tug..just so it wouldnt be overtightend
  7. reckedracing
    NY
    werd, i never torqued an intake either...
  8. eg6sir
    well here is another question.... i bought a new gasket put the intake mani. on and i had a leak...so pulled it off again.. and one of my injector o-rings broke so i sprayed gas all over and a little got on the gasket...Is the gasket still usable...????
  9. reckedracing
    NY
    in theory once its been torqued it should not be re-used, but i would prob try and use it...
    just be ready to shut it down if it revs out of control
  10. phyregod
    phyregod !!YTINASNI
    Central Texas
    There isn't a specific bolt pattern to follow, just work your way from the center out. I always hand tighten from the middle out, then torque them down from the middle out. Be sure to work the top and bottom bolts evenly.
    I'd do something like:
    *edit*
    You should replace the gasket. I'm not saying that the one you have won't work again, but it would be MUCH better to replace it.
    And, DO use a torque wrench on the IM if at all possible. Auto-zone will lend you one for free, you just have to slap down a deposit.
  11. eg6sir
    hey thanks alot..thats all i was lookin for...
  12. phyregod
    phyregod !!YTINASNI
    Central Texas
    I changed it up.. If you already wrote it down/printed it, re-record it. I had mis-placed the center bolt on the old one due to the angle of the thing.. Kind of an illusion. The other one will work, but this one is the right one.
