tps question
gunz2165
i switch the tps sensor on my h23 when i did the swap in my accord. how to i set the tps now that ive put it in?
By set it I assume you mean for the correct voltage sweep. Just hook a volt meter to the ground and signal wire. Should read .5 at idle and 4.5 at WOT. Don't forget to reset your ECU after doing this because the KAM in your ecu adapts to wear. So say your old TPS was reading .3 at idle, the KAM now recognizes this as normal. You need to reset it so it learns that .5 is normal again.
