TPS replacement Q?
Discussion in 'HYBRID -> EG-EK / DC' started by dwn2low, Jul 3, 2005.
  1. dwn2low
    dwn2low Senior Member
    Little Rock AR
    How the heck do you replace the tps I broke mine on my b18b while removing it. I noticed there are no screws just nuby rivit like things? Please help. :worthy:
  2. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    Aren't they the torx screw things?
  3. dwn2low
    Little Rock AR
    No these things look like it has ben pressed or welded in
  4. VTECPOWER
    Winchester, VA
    Hmm, idk, with mine on my b16 it has torx screws that I had to tighten down.
  5. Johnnylawless
    Johnnylawless Senior Member
    use a small file to file a slit in them,then use a small flatblade screwdriver to get them out.
    EDIT: they are screws that are blunt top so nobody messes with the factory calibration. just use the method above thats how i fixed mine.
  6. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    wow..Interesting..Good Question..I always wanted to know how to remove the damn thing...
    and you..wow ..Good answer..Im gonna try that...
  7. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    i used a small chisel on it and a small hammer until it turned and it came right off!
