TPS sensor
CrXRacr
How do you remove a tps sensor from a 91 hf throttle body :angry: please help...thanks
its true the seach thing sucks, but to answer your question smashed4thgen was right, thats the only way to do it without breaking it (i know i broke mine). I never knew it was suck an imprtant peice either.
yeah they look like rivets, but they are just shear bolts, cut a slot in them with a hacksaw or dremel and then just take them out with a slotted screwdriver- when you throw the new one on, just find a couple of allen bolts that are the correct thread and length
save yourself a lot of time and trouble - just get another throttle body and swap the whole thing
Whatever! The TPS is easy to remove, it's not a lot of trouble at all.
I fount a cutoff wheel to work well. Use it to make a slot, then use a flathead screwdriver to remove it. Easy Peasy.
