Hello all,
I've been having issues regarding my Throttle Position Sensor (TPS). I was getting Error Code 7, so I looked up troubleshooting guides related to the TPS. I followed them step by step and found out that my TPS is giving the wrong voltages.
It was getting 5.0 volts at closed throttle and around 0 volts at wide open throttle. I proceeded to replace the TPS with a new one and problem is STILL happening. I am still getting 5V at closed and 0V at wide open. I tested and made sure the wires were going to the correct pins on the ECU. Could my ECU be bad? Has anyone had this happen before? It is really frustrating, there is nothing worse than losing power at wide open throttle
Thanks
Thanks
