Does anyonw know which wire comming off the tps ids the voltage output wire. Its a 1995 integra ls. There is a green wire, yellow with black stripe and a red with black stripe.
yellow is power to the tps from the ECU red is the signal (usually the one you need test) going back to the ECU green is the ground you need to utilize to get an acurate reading off the signal wire.
extra note, .45v closed throttle 4.5v wide open throttle
