Tps
boosted_ek
I put on a 'new" TPS on my swap, but now unfortunately the car will not drive. I take it outta 1st hit the gas and nothing happens? The revv's don't climb. I checked if it was the throttle cable but it is opening up the plate, so I assume it is the tps which I haven't calibrated. I've never heard of tps' doing this though, so I guess i'm wondering if this is related to my non-calibrated sensor or not.
and no i'm not running rich.
did you install the tps correctly? it has a rotor that needs to be lined up on the back of the tb.
