Tranny and clutch help
B18CBeast
Just got my B18c into my hatch and everything works great except the clutch squeals out of first gear (stage 2) and the tranny doesn't want to go into gear very easily. I still have to get the small dowel and a new boot for the end of the shift linkage because I have a bolt in there now, but I don't think that is the problem. Any help would be great.
this is kind of a dumb question, but did you refill all tranny fluid, and re calibrate the clutch (make sure it is adjusted properly, and bleed it after topping it off??)
yeah gsr linkage and everything, could it be the wrong fluid? What do you recommend
