Tranny bolt up
delsolcharlie
Will a d15b vtec obd1 transmission bolt up directly to my D16Z6
does anyone know if i can use stock ecu converting it from auto to manual
is this OBD1 tranny runnin cable or hydraulic??
well, to tell if it is hydralic or cable is that hydralic has a shift fork that extends out of the tranny housing. As far as the ECU goes, you will need to convert it, I dunno if you can use the stock one or not, search around. And yes, it should bolt up...all D-series work with D-series
