tranny bracket
Discussion in 'HYBRID -> EG-EK / DC' started by custompainter, Mar 1, 2008.
  1. custompainter
    custompainter drive it like U stole it
    central CT
    i have a rear tranny bracket from a type R integra can i use that t-bracket to do a b18 swap in a 99 EK or do i have to get the SI rear T-bracket ??
  2. custompainter
    central CT
    i guess i'll find out for myself
  3. formby
    formby learning in progress
    must be si
    i have a gsr bracket that did not fit when i did my swap. had to buy the si one, it is shorter.
  4. custompainter
    central CT
    i just found that out LOL..... fun stuff
    the type R braket that i have is an inch longer
    so i'm attemting to modify the braket so far i've trimmed out a bit of the inside so i can get it to sit farther back
    and i've redrilled the mount hole 1 inch closer
    now i have to get it to clear the cross member - it's got a lip and if i can get it 1/2 inch i'm golden
  5. custompainter
    central CT
    this is for anyone who is reading you can make a integra rear tranny bracket fit in a EK
    it takes a little cutting and welding but i got it to work !!
  6. UNDR8D
    UNDR8D ...has a job!
    8OH!5
    Yah. props to you for hacking. I was going to cut up my D bracket to make it fit or build one but I got lazy and just bought it. It was so much easier. Then i had to try to get it to fit with the motor already in the car....eeek!
  7. custompainter
    central CT
    a little hacking... but most was just a few adjustments ..... LOL
