tranny fluid
Discussion in 'General Tech and Maintenance' started by leonard3343826, Jul 22, 2006.
  1. leonard3343826
    leonard3343826 Junior Member
    what up everybody,
    does anyone know what auto trans fluid goes into a jdm b16a/auto tranny combo? i believe the donor vehicle was a 93 civic sir. thanks for any help.
  2. DwnShftPrincess
    DwnShftPrincess Senior Member
    Orangeburg, SC
    dexron III i think. call your local honda service center to be sure
  3. leonard3343826
  4. divisii
    divisii Member
    The dumba* mechanic that came highly recommended to me thought he could use oil on my 5spd manual .. I noticed it was kinda stiff to shift, he said my trans was getting old. Though I now have symptoms of input bearing shaft damage, I switched to Honda fluids & the thing is smooth.
    Use only the Honda stuff, because it works & it's cheaper than replacing parts.
  5. Taco15
    Tallahassee Fl
    honda fluid period! I used alot of crap on my 5 speed. regular oil,gear oil,syncromesh. i finally busted my tranny. using the same s worn syncros and gears i put a new case and diff. in it. i used honda MTF and it shifts so smooth now.
    HONDA MTF ftw!
