tranny grinding or bearing
Discussion in 'General Tech and Maintenance' started by KyleCrews, Apr 13, 2004.
  1. KyleCrews
    KyleCrews Senior Member
    Jacksonville, FL
    My tranny is making a weird noise from around 4500 to 5000 rpms and i'm not sure if its a grinding or a messed up bearing. I only hear it while the car is moving and the clutch is pressed if i rev the engine to around 4500. I also hear it at the same rpm in between shifts. If anyone knows what might be causing this that would be great. I've got an h23 if that helps. Thanks
  2. KyleCrews
    Jacksonville, FL
    come on guys i really need to figure this out. If it something serious i don't want to lose the whole tranny over this.
  3. 97hatch
    97hatch ?
    Anderson IN
    if its rpm based and it does it with the clutch disengaged it probaly has somthing to do with the motor does it do it if your stoped.
  4. KyleCrews
    Jacksonville, FL
    no only when the car is moving
  5. KyleCrews
    Jacksonville, FL
