tranny internals swap
Discussion in 'General Tech and Maintenance' started by TAGURIT, Dec 11, 2006.
  1. TAGURIT
    TAGURIT New Member
    have a friend that has a b16 tranny that has a cracked housing, what i want to know is can you take the internals out from the b16 and put it into a b18 tranny from a 91 da integra? any info will be great.
  2. theman631
    theman631 New Member
    Unbelievable! I have the same problem. B16a1 tranny (cable tranny) is cracked and leaking and I have a B18a1 ls tranny that has bad third gear. I don't want the ls gearing so I hope that I can use the b16 internals in the b18 housing. Thanks in advance. :D
  3. TAGURIT
    TAGURIT New Member
    help..........
    anyone have any info on this???? c'mon this is honda swap someone has to know if this is possible.....
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    I've never heard of them being different; but if the shafts don't fit you can always just swap the gear sets.
  5. TAGURIT
    TAGURIT New Member
    thank you for the reply, anyone else??
  6. theman631
    I am looking for someone who is sure that it will work before I go to the trouble in an unheated garage and 15 degrees out. Thanks in advance
  7. theman631
    Anyone? Just looking for a sure answer. Thanks in advance.
