santaclaus57
So I have an issue with my 5 speed. The clutch pedal goes to the floor and the car will start but there are absolutely no gears, the shifter won't go into gear wether it's started or not.
Ideas?
Ideas?
yea in that case it sounds like a bad slaveya, it goes into gear when the car is off but not when it's running.
Thnx for the advice on the slave cylinder, I'll have to replace it.
