Tranny Leak
ebisu8
I have a 91' Civic HB with a B16 in it/ I'm using a YS-1 trans. The passenger side axle does not sit all the way in and seems to almost pop out and it's Leaking really bad. I'm using 90'-93' inetgra axles and I removed the spacer and dust sheilds from the inner hub Why is this not fitting right. What do I have to do or what axle do I have to use. The driver side with the intermediate shaft sits fine it's the other side. I need help ASAP> Thanks.
If you have the jdm intermediate shaft. You will need the 86-89 integra drivers side axle and 90-93 passenger. I think thats how it goes.
