Tranny Leaking Oil
mr.paower
Member
my tranny is leaking,i'm sure its not from the motor,so where could it b comin from???? another question is when i changed my headgasket it seemed like i lost some power seems to b laggin a little now...btw my engine is b16...no mods
is the drain plug secure on the trans?
did you crack it open and not reseal it??
who did hte headgasket change?
drain plug is secure...
the guy i bought the swap from prob opened it...
and I did the head gasket....but it seems to be fine ...I advance the timing bout 2 degrees
is it leaking insige the clutch housing like maby the input shaft or is it maby the drive axle seals if it is the in put shaft get it fixed asap b4 it gets oul on the clutch and you have to replace it also and you may have a bad input shaft bearing and thats what made your seal go bad if it is leaking where the two halves meet up you will have to drop the trans pop it open and reseal it i dont know about you but opening a trans has allways worried me so ive never done it but seen it done many times
