How often do the bearings in the trans go? I think mine is on its way. Its got 175K on it and makes an annoying noise at idle, and in first through third gears that I can hear it.. I know its not the throw out bearing because even with pressure, the noise should go away if it were. It also grinds third if get above 5K but I don't hardly beat on the car since I use it to get back and foward to work. But it is an annoying wine that follows the car up, and is kind of intermittent, but does follow the rpms, getting a little louder, and is slowly getting louder... The car is a 95 Civic Ex, 5 Spd... Thanks Gary
