C civic_types Senior Member May 4, 2004 #1 What type of oil should I use? I have a B16A SIR2, Y21 Tranny with LSD -
9 97hatch ? May 4, 2004 #2 i like gm syncromesh it seams to make it shift real nice. other options are honda MTF, 10w30or 10w40, or you can even use ATF(not recomended)
C civic_types Senior Member May 5, 2004 #7 that kaaz is 80w90 do you think that that is a bit to thick. Click to expand... Why would a normal Honda Transmission take 10W30 and an LSD take 80W90? Or is this 80W90 simply an additive? BTW, I live in canada, KAAZ products are hard to come by. Do other oil manufacturers produce a limited slip differential oil?
9 97hatch ? May 6, 2004 #8 yes there are other places to get the limited slip aditive but i dont think that honda lsd need it i think that they are designed to work with out it.
