tranny only go in one way?
Discussion in 'General Tech and Maintenance' started by ryangt, Jan 7, 2005.
  1. ryangt
    ryangt Senior Member
    puttin the hf trans back on my rex i got everything lined up and the trans bolted up, i had to tap it all the way on with the mallet but i was curious before i put all the shit back on if its on right? i had my girl rotate tha crank by hand with a socket untill the trans pushed in. Is this the proper procedure? Can i check to verify that the trans is engaging?
    any help will be very much appreciated
    thanks in advance
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    the trans only goes on one way.
  3. 92civicb18b1
    you should have slid it on and rotated it to match the holes but its the same thing.
  4. ryangt
  5. UDT
    UDT Senior Member
    california
    Theres some metal nobies on the trany that will only let it sit in the bell housing one way, the right way.
  6. ryangt
    thansk again, is there any way to check for positive clutch engagement before i put all this stuff back together?
