Tranny Problem!!!
ricancivic_91
I got a 96 integ LS in my 91 civic hatch, Im having problem with the tranny in 5th when Im in the the highway it pops out. I can only do bout 55 to 60mph so that it stays in 5th and even then sometimes it pops out. Can it be a synchro or wat?
sounds like a synchro yep. either way there's no miracle cure for that. either need a new tranny, or tear apart that one and fix it.
Ok thanxs man! Can u help me wit this one also I have a 90 integra that I want to make into a manual trans, wat do I need to make it from automatic to a manual. I heard that I have to change the trans mount but from wat year and do i need anything else to make this happen?
i don't know of everything, but you will need the trans itself, clutch, clutch pedal assembly, clutch cable, 90-93 integra manual tranny side bracket, 90-93 manual intermediate shaft, shift linkages, and a manual obd0 pr4 ecu.
