tranny q
Discussion in 'HYBRID -> ED-EF / DA' started by jimboburgess, Jul 2, 2005.
  1. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    What tranny mate up to ZC motors
    does a dohc only fit with a dohc trans
    i am thinking of putting the dohc ZC from hmotors into an 89 crx si.
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Any 88-00 D series transmission will bolt up to any 88-00 D series engine. Just make sure you have the right clutch combination if you're playing with the 88-91 series, since there were different spline counts and flywheel sizes.
  3. Drake
    Drake Well-Known Member VIP
    If you have the cash try and score the ZC tranny from Hmotors. The ZC has a pretty close gear ratio making it fairly quick. That is the tranny im running in my crx. My advice would be put a SI final drive in it to keep the freeway RPMs down.
  4. jimboburgess
    nyc
    ok, thanks for the info. are all of the ZC motors considered d series?
  5. phunky.buddha
    Yup. The ZC designation is what was given to the highest performing D series engine of each type- SOHC, DOHC, SOHC VTEC.
  6. Drake
    Really? Damn good thing someone cleared that up before I wasted my cash. When Im doin 70-75 down the freeway im turning about 4 grand. Thank you for clearing that up Calesta.
