Tranny Swap ECU
delsolcharlie
i just got my new 5 speed today ..all it is is the tranny, no clutch no flywheel...inside the casing there is a arm that floats on a little ball and and the ball on the slave clyinder and meets in the middle on a piece that goes over the shaft.how does the clutch and flywheel fit on??
i know i need all the linkage, clutch, flywheel, clutch master clyinder, pedals...and i have a question about the ECU..the auto ECU...do i have to get a manual ECU or can i use this??
eBay Motors: Racing Spec ECU Chip 92-95 Honda Civic EX/SI P28 New (item 290102994470 end time Apr-11-07 00:04:36 PDT)
it says "[FONT=Verdana, Arial, Helvetica, sans-serif]Also converts automatic ecu's to manual transmission" is this true???
[/FONT]
