Tranny Swap Help
Discussion in 'Civic and del Sol - EG and EK' started by Tein, Oct 3, 2008.
  1. Tein
    Tein So much with a little D
    Kissimmee, FL
    I am basically done with my swap and engine built.., but I need to purchase the Left Lower engine mount (this is the one that goes on the driver side). The manual is different at the auto.... My question is do I need to keep using an auto mount or a manual? cause this mount is not on the tranny side and why are they different? do the holes are made different and they are already set up for an auto chassis or the distance has change with the new manual tranny?
  2. Tein
    Kissimmee, FL
    I need HELP!! if I made a tranny swap from auto to 5 speed,,, what enigine mount do I need for the left lower mount (driver side) auto or manual mount?
    Any one knows?
  3. EP3Hatch1987
    EP3Hatch1987 Meeeeooowww!!!!!
    why do want to change it?
  4. Tein
    Kissimmee, FL
    My ride came with a auto tranny, I swap the tranny to a mannual and the mount that came with the car (the auto mount is broke) so my question is do I need a auto or manual left lower mount?
  5. EP3Hatch1987
    If its for the tranny your gunna need a manual mount.. If not 4 the tranny you can use the auto mount
  6. Tein
    Kissimmee, FL
    Yes, the mount goes on the driver side,, its not on the tranny side but then why the left lower engine mount is diferent on a auto and manual tranny?
    So you said that I should keep the auto right?
  7. EP3Hatch1987
    Yeah the auto one will work..
